Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2007-2013: Why Won't My Truck Start?
Guide to diagnose trouble and recommended solutions
Won't Start NBS
I know we had alot of post on this awhile back & I have an update (Sort of). I had the problem twice over a year ago & none since. Now it's 100+ in Texas & still no problem she starts every time.Friday I took her to the dealer to have some waranty work (Windshield wiper fluid heater harnes) and as an after thought I told them about it not starting. They found a dead cell in my battery, now I know hot weather is hard on batteries,but to go 1/2 of winter & 1/2 of summer with no problem then have a dead cell? Was it dead a year ago and was still starting her?
Charlie
Charlie
Extreme heat and high humidity tend to take their toll on battery connections and wires.
Check your negative cable and your engine/firewall ground strap particularly carefully.
Late 06, all 07,all 08, half of 09 is almost three years, the bare minimum for corroded cables and wires under optimum conditions.
I would suspect the engine ground strap, especially if the truck gets offroad use.
Thanks for the info, but I work with batteries everyday. My truck had the first issue of not starting with 15,000 miles I had the radio on about 25 min. between sesions at the track. Turned it off & no lights were left on & it was dead when I tried to start it. Next time I was on the track helping tear down after a MC race with my flashers on (not longer than 1 hour) & it was dead again. This was last summer in Texas & yes it was hot,but after we got it started it was fine the next 10,000 miles. Summer & winter as an after thought I had the dealer look at it & it had a bad cell, but it was still starting every day in 100+ heat.
I know in some older post alot of NBS Silverado owners were having the same problem & was just trying to give an update & see if anyone else was still having the problem!
All your points are valid, & someone withan older Silverado may find them of use.
Thanks Again
Charlie
Thanks Again
Charlie
Thanks Again
Charlie
Thanks Again
Charlie
If you're so knowledgable about batteries, why are you asking questions about them?
Rivereye posted some very good info that DOES apply to your truck. I have seen poor grounds cause funky things at 100km....So even you're NBS may find them of use at at least 25000 miles.
All I'm saying is I along with someother people have had battery problems. If it was a bad ground why would it start for the next year (0) -(110)F because bad grounds do not fix them selves. Also the dealer said I had a dead cell, but the truck started in HOT & Cold weather?
Charlie
PS
Yes I know alot about Batteries, but not the wiring on my 2007 Silverado! Now my 55 I can take it apart & put it back togeather blindfolded. I also know the wiring inside out & it does not have a computer? Hummm could that be the problem?
Charlie
PS
ZChevyAK
November 13th, 2015 6:45 PM
larry_chip
June 2nd, 2007 3:20 PM
bobinpa
February 16th, 2007 11:58 AM
