YAY!...A/C is back....(kinda).
Found out why no a/c recently, dryer was a plugged up. $75.00 later I got a/c again.....but......I've still go the problem of after running 20-30 min the air flow from the vents get real weak. I can hear the fan motor running, I can change to defrost and so on, it's just the air flow is weak. After a while it comes back and then goes weak again. Also, I should mention, the highest fan setting has never worked. I hope someone has run into this problem and can tell me what needs to be done as I know just enough to be really dangerous. Thanks in advance for all the help....
terrymanis1
August 29th, 2014 9:03 AM
