Site Feedback THIS SECTION IS FOR SITE RELATED ISSUES ONLY!! NO TECHNICAL QUESTIONS OR ANYTHING RELATED TO FIXING AN AUTOMOBILE
09' Impala radiator fan won't shut off
Old Oct 5, 2017 | 12:09 AM
Jerad's Avatar
Default 09' Impala radiator fan won't shut off
No check engine light, throws no codes, does not over heat, but the fans won't stop running. Has anyone experienced anything like this before?
Old Oct 5, 2017 | 2:58 AM
First check the temperature sensor on the engine.
Old Oct 7, 2017 | 4:50 AM
Jerad's Avatar
Default Radiator fan
Thank you for the reply oldchevy. I checked the relays and they weren't the problem. I installed a battery disconnect in the meantime to get me by til the weekend. I was hoping that if the coolant sensor was bad that it would throw a code or check engine light would come on. I'm guessing that's not the case, because of your reply. Guess I know what I'm doing tomorrow.
Any other feedback or tips would be very appreciated and thank you again.
Old Oct 25, 2017 | 10:52 PM
Jerad's Avatar
Default Thanks guy
Changed the temp/sen and problem solved. Sorry for the lack of haste in my update. Still confused on why the bad sensor wouldn't throw a code
