Engine Overheating Issue
Looking for advice.
fairly recently, ive had a few engine temp issues. My engine temp was reading low and the fan was running at high speed next to constantly.I replaced the thermostat and the temp sensor and it fixed the issue. Then a little later I leaked alot of antifreeze and had to replace the reservoir, which fixed that issue. Now the fan is running at high speeds again, but doing the opposite of what it before, the temp gauze on the dash is reading hot. Around 210 (normal temp) on straight stretches but when Going uphill it's reaching near 250. There is no further coolant loss and the engine oil is not milky in any way. I've done multiple pressure tests and just replaced the temp sensor for the second time. Any ideas as to what could cause this? The vehicle is a 2017 chevy silverado 1500 LT.
rickybobby89 (Yesterday)
I'm going to try completely draining the system today after work. Then putting in another thermostat. Then refilling. See if it changes anything. I'll get back to you and let you know. Maybe it's air, maybe I got a faulty thermostat. I'm also thinking I may have done it to myself. Because between the thermostat being replaced, and the leak being found and repaired i used some of that antifreeze stop leak. But never drained it out. I'm thinking it's a possibility that it may have somehow gunked up the new thermostat. O won't be able to tell until I do it though.
Cowetacountyoutdoorsmen
February 8th, 2015 3:03 AM
