Fires but won't stay running
The dash in my truck was all cracked so I swapped it out with another one. I had to drop the steering column and pull the wiring harness out and after it was all back together the truck would fire and after a half second stall. I pulled the dash again to check the connections and for pinched wires and everything looks as it should. All my fuses are good too. Any thoughts on why it won't stay running?
If it ran before you did the work then it has to be something under the dash that looks good but is not making a good connection. Check all the wires and connectors again real carefully. It is probably something hard to see at first glance.
