Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2009 Chevy Aveo5 U0401 Trouble code
Old Jun 25, 2019 | 11:23 PM
Bryan Wyandt's Avatar
Default 2009 Chevy Aveo5 U0401 Trouble code
I got a 2009 Chevy Aveo5 with 101,000 miles. Well I got the car pretty cheap and one of the issues that keeps coming up is the U0401 Code "Invalid Data Received From ECM/PCM "A"", well I'll be going down the road and the hold on the dash with start flashing I would loose A/C and the Thermostat stops working. I already know my thermostat is stuck open and so I'm going to replace that cause I got a P2181 and a P0128. I don't know if that would cause the U0401 code. The car was in a collision with a dear before I bought it. The radiator support mount was repaired. I don't know if that would cause it either maybe if some wire was cut or whoever repaired it disconnected something. I can reset the engine codes and everything is normal for about 50 miles then it comes back on. Also got a P0016 which I know is the Crankshaft, Camshaft sensors. I don't know if any of this could cause it, but I'm just trying to give all the details of whats going on.
Old Jun 26, 2019 | 12:29 AM
oilcanhenry's Avatar
U0401 Fault Symptoms :
  1. Check engine light comes on
  2. Engine stalling or misfiring
  3. Engine performance issues
  4. Car not starting
U0401 engine trouble code is a sort of network trouble code and U0401 code can be about replacing a broken oxygen sensor which can eventually lead to a burned up catalytic convertor. There are other thing that can set this code off, but this seems most common.
Old Jun 26, 2019 | 9:59 AM
KChevy75's Avatar
Sounds like there's a short somewhere. GM also has issues with defective fuse blocks in various models. The copper wires inside them start developing breaks that sometimes only show up when the engine bay warms up.
A good code reader that can read GM specific modules might provide more information that doesn't show up with a standard OBDII reader.
Old Aug 24, 2019 | 7:15 AM
Jennitran's Avatar
I got a 2009 Chevy Aveo5 with 101,000 miles. Well I got the car pretty cheap and one of the issues that keeps coming up is the U0401 Code "Invalid Data Received From ECM/PCM "A"", well I'll be going down the road and the hold on the dash with start flashing I would loose A/C and the Thermostat stops working. I already know my thermostat is stuck open and so I'm going to replace that cause I got a P2181 and a P0128. I don't know if that would cause the U0401 code. The car was in a collision with a dear before I bought it. The radiator support mount was repaired. I don't know if that would cause it either maybe if some wire was cut or whoever repaired it disconnected something. I can reset the engine codes and everything is normal for about 50 miles then it comes back on. Also got a P0016 which I know is the Crankshaft, Camshaft sensors. I don't know if any of this could cause it, but I'm just trying to give all the details of whats going on. If you are looking for the best battery maintainer, visit this site to find the suitable one.
Let check your battery or alternator if there is any issue with them. Also you can check to see if you have water on the passenger side getting to the smart junction box. It also cause this issue.
bl89tbi
Dec 17, 2015 3:10 PM
shetluck
May 30, 2013 6:58 PM
tloestreich
Jun 14, 2012 10:45 AM
2wd-K5
Cobalt
Aug 21, 2010 10:00 PM
bbish0p
Nov 17, 2009 7:54 PM
