Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Car will not shut off
Old Jan 17, 2017 | 4:47 PM
lasmolinas's Avatar
Default Car will not shut off
my sister-in-law's 2009 chevy aveo will not shut off once the key has been turned to the off position and completely removed the ignition. She took it to a mechanic and they couldn't see any issues. Have you heard/seen this issue before? Is this a wiring issue?
Old Jan 18, 2017 | 8:32 AM
bad ignition switch?
does the car have an aftermarket remote start?
so the problem wasn't active when the mechanics looked at it?
Old Jan 18, 2017 | 8:42 AM
lasmolinas's Avatar
Default No after market starter
There is no after market starter and the issue was not active during the mechanic's inspection.
Old Jan 18, 2017 | 9:00 PM
if the fault is not active, no mechanic will be able to find the fault.
Old Mar 8, 2017 | 10:53 AM
WyrTwister's Avatar
Find a wiring diagram . Determine a circuit / fuse that should be " hot " when the car is running .
When the car is acting up , with the ignition off & key out , measure voltage & see if that circuit / fuse is hot .
If it is , I would figure the ignition switch may be bad .
Also , look for a relay that actually " turns on " all the circuits / fuses that should be hot with ignition on . If it has such a relay , it may be sticking closed ?
God bless
Wyr
