ECM Question
Hey everyone, I tried searching the thread but it didn't come up with anything under "ECM", so I'm going to make a new post.
I'm wondering if anyone knows how to reset the ECM on the 06 Aveo (1.6L), and/or if you know where I can get a cheap replacement for one? And is this something that I can install myself? I'm fairly technical.
Since I can see it now; "why do you need an ECM?" One word: P2135. ...I hate that code.
So, I bought my Aveo 2 years ago because it was the only car that we could afford. After about 8 months it threw the P2135 code (accelerator pedal position sensor). So, I bought a new pedal assembly and replaced it.
The code went away...for about 6 or 7 months, then it came back. So, highly upset, I bought a new one and replaced it again. The code went away.
5 months later the code came back. This pedal was still under warranty. At this point I'm thinking it's not the pedal, but I replaced it again anyway. The error went away.
Until it came back. This time my mechanic noticed that my throttle-body was faulty and we replaced it. That was April. The code went away.
And, Saturday, the code came back. Logically; it's not the actual sensor. There's no way that 3 different sensors will go bad in that time frame. And it's not the throttle body, that was just replaced. So it's either the wiring, or the computer. If it were a wiring issue the code would come back almost immediately after replacing the part because a physical connection failure due to a broken wire isn't going to be intermittent. So, that means its the computer. The mechanic is quoting me $600-700. I've already spent more than $4000 in replairs in the last 2 years; 2x pedal assemblies, throttle body, front axle, radiator, front passenger wheel hub, front windshield, etc. I'm getting sick of fixing this car. The mechanic is telling me it'll take a week for the computer to get here and that it'll take hours to complete the work. I'm sure I can find it easier. If not, I at least want to reset the computer to buy some time. It's the only car we have and I have to get to work. If the car dies completely I'm screwed. Any ideas or suggestions are appreciated.
Thanks in advance!
-John
Thanks in advance! -John
I don't know where it is located except under the hood. You need to take your vin to wherever you trade, I'd suggest a reconditioned one, would be alot cheaper than new. It will have to be programmed thats why you need the vin. Is the sensor a "quality one? Cheap stuff won't last but about as long as you are having.
I would hope it was a "quality" sensor. One of them I ordered through AutoZone and the other one through my dealership.
I know physically where the ECM is at within the engine compartment.
I was asking more along the lines of where I could buy a replacement unit. Luckily my wife managed to track one down through the local dealership for just a few hundred bucks and our mechanic is going to reprogram it, so hopefully the car will stay running until the part gets here.
Thanks in advance!
-John
Next time, to test, unplug the TPS and then plug it back in, it might be a bad connection somewhere...
CantHideRedneck
May 28, 2010 10:59 AM
