Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Fuel pump
Old Apr 20, 2024 | 5:05 PM
DansCar's Avatar
Default Fuel pump
hi everyone, I'm new to this forum thing so I'm sorry if I'm making mistakes. My name is Frank and I'm working on my nephew's car. It's a 2005 Aveo, 1.6 L engine standard shift. The problem that I'm having is that the fuel pump wont stay running after start up. I can order it to run with my scanner but as soon as the run command times out the pump shut down. I have a few questions.
Is the oil pressure sensor involved in keeping the fuel pump running after start up? Or is it that the ecu might use the ignition signal to keep the pump running after start up. I'm getting different opinions on both. if it's the ign signal does any one know which pin number on the ecu it might be. Where can I obtain a decent shop manual for this car. Please help. Thank you.
Old Apr 21, 2024 | 7:01 AM
Welcome from Florida. These might help you. Good Luck!
Chevrolet Aveo (04-11) Haynes Repair Manual (Haynes Automotive): Haynes Publishing: 9781620922460: Amazon.com: Books Chevrolet Aveo (04-11) Haynes Repair Manual (Haynes Automotive): Haynes Publishing: 9781620922460: Amazon.com: Books
2005 aveo repair manual for sale | eBay
Old Apr 21, 2024 | 8:06 AM
Rednucleus's Avatar
Welcome from WA -please report back on your progress
Old Apr 28, 2024 | 5:35 AM
MorganHolmes's Avatar
Welcome, I am also new here.
Old Apr 28, 2024 | 5:57 AM
DansCar's Avatar
Default Still in the dark
Thank you all for your assistance. I replaced the fuel pump relay just in case. It seemed to be a weak link. The car does not have an immobilizer which could be a reason why the pumps may not run. I've chased down many leads as this is very intermittent. He's afraid to use the car because it fails to start every so often. Right now it's working fine. Do to your assistance I found the original factory service manual. Ever since I forced the pump to run using my scanner it seems to be working fine. If anything changes I'll report back. Thank you again for your assistance
Joe_The_Guy
Oct 29, 2021 9:50 PM
Joe_The_Guy
Oct 27, 2021 6:28 PM
DuckyD
Jan 2, 2011 8:29 PM
LHHEMS
Dec 28, 2007 7:18 AM
