Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
PO315 code won't clear
Old Aug 21, 2014 | 8:40 PM
dlg's Avatar
dlg
Default PO315 code won't clear
I have a 2006 Aveo and the code PO315 shows up and the CEL is on all the time. I took it in to have the crank relearn done and it will the light will go off only to come back on as soon as the key is put in the ignition. He tried putting on the original crank sensor (which was replaced along with an ignition coil and manifold gasket) and both sensors gave him the exact same reading.
He unhooked the battery and again, the code would go off but come back on again.
I do not know what to ask them to look for, any advice would be greatly appreciated. Thank you
lsufan88
Feb 4, 2012 10:31 AM
PatrykKoul
Dec 28, 2007 1:15 AM
AT Tahoe
Sep 28, 2007 3:45 PM
BostonGuy
Jul 18, 2007 10:56 AM
ironcy
Jan 19, 2007 2:03 AM
