specific, strange symptoms, please help!
So i'm driving a 2006 aveo that started making a sound that sounded sort of like the tab on brake pads might be rubbing. Drove through Canada with sound getting worse but not affecting handling. Now it's gotten much much louder, sounds like a low pitched squeal at medium speeds, and sounds much more like a grinding when I come up to a stop sign. Louder turning wheel to right, weirdest thing is that even at low speeds when the sound is loudest, it stops if you hit the gas. Also worth saying that it sounds related to tire, as in the sound is intermittent, faster if the tire is spinning faster.already changed rotor and brake pad and it is not a bearing. Any ideas???
dljones3626
July 25th, 2010 10:45 PM
