Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Tires?
Old Nov 5, 2009 | 6:50 PM
mattwv's Avatar
Default Tires?
Hey everyone,
I got two questions. My 2006 AVEO LS is going through front tires like crazy! I am driving 700 miles a week for school but I have only had these tires for around 8,000 miles and they are already almost shot. Anyone else have this issue? I don`t think its the brand tires because these are good tires and this is the second set I have had since I got the car. When I say they are good tires I mean that they cost like 80 bucks each when I got them. I gotthe car when it had around 23,000 on it and it now has 36,000 on it.
Next is there any other size tire I could run? I have the 15 inch wheels currently running the stock 185/55/15. These tires cost way more than are other vehicle which has 205/75/15 tires. I know there is not much room there but will a 185/65/15 fit? I don`t understand why chevy had to put this size tires on these cars in the first place.
Thanks!
Matt
Old Nov 7, 2009 | 12:54 PM
desrtrat's Avatar
i would find a good front end shop and have them look at it..how are your rear tires? any excess ware on them? are you the original owner of the car? i know a lot of questions but need a little more info. i have a 08 with 28k mi. and still have over 1/2 tread left on all 4. I'll get back on what tires i have..
Old Nov 7, 2009 | 6:19 PM
mattwv's Avatar
Yes I will get the front end checked out for sure! The rear tires are great. They seem to be wearing perfectly normal. No I got the car when it had 23K on it so I have only had it since this summer.
Thanks
Old Nov 7, 2009 | 6:25 PM
nauticstar87's Avatar
80 dollars is cheap for me. tires on my wifes eclipse cost 110 a piece. And those are just decent tires not even great tires. Their an off brand.
Old Nov 7, 2009 | 6:37 PM
rubrhammer's Avatar
Changing to the tire size you mentioned would change tire diameter by approximateli 1-1/2 inches. That is quite a bit and would throw your spedo off by about 5 mph.
Old Nov 8, 2009 | 3:19 PM
desrtrat's Avatar
Thanks
i have the 185-55-15 hancooks. factory tires. also when you get the alignment done, ask them to look and see if there is any damage from a accident. if so there could be your issue on going Thur so many tires
good luck
Old Nov 10, 2009 | 4:42 PM
mattwv's Avatar
Thanks guys! I will get the front end checked out as soon as I get a day off.
Old Jan 21, 2010 | 10:25 AM
choxon's Avatar
5mph? i would rather say 5%,
i`ve put 185/65 15 on my chevy 4d, it works pretty fine, but - it is little tricky, mileage is little "cut displayed" with that i mean that you get less mileage displayed than you did.
you can try different option, get smaller rims, lets say 14˝ and then you put 65s on it (or 75s, that should be calculated before doing action), and you have same diameter with, lets say 185/65 14, as you do with 185/55 15... something like that.
so back to important. i have 185/65 winter tyres on it, no problems using it unless what was said earlyer. but i dont mind about it. its even more comfortable with bigger circle diameter, its softer on road bumps
i have done about 40000km with my base M+S tires, they are still usable for summer conditions, before anything you should definately get your front wheels checked...
sorry if my english is bad, im croatian, lol...
JHarris8732
Nov 10, 2011 11:25 AM
scootr68
Jul 23, 2010 6:06 PM
bocajeff
10
Mar 31, 2010 12:41 PM
Andy
Jan 29, 2007 11:57 PM
