Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
What is the correct MAP sensor number?
Old Apr 30, 2017 | 8:42 AM
nedc's Avatar
Default What is the correct MAP sensor number?
Hello!
I have Aveo T250 1.6. Can someone say what should be the MAP sensor number for this model?
Now - 96330547. But, for example, in this directory, this number does not match my model.
http://www.fae.es/files/product/pdf/familia-15-47.pdf
GM has a lot of numbers of MAP sensors. What is the difference between them, except the form factor?
Old Apr 30, 2017 | 9:26 AM
kevinkpk's Avatar
Some have 4 wire, others 3 wire. Also the bar altitude usually 3 bar, or 5 bar
Old Feb 13, 2020 | 9:10 PM
Karakurt Pictures's Avatar
Banned
Originally Posted by nedc
Hello!
If I am not mistaken, then the correct MAP sensor number for this model is 5841111. 1111 scares me a little, because it is an unusual number and it has a special meaning. I don’t know if you understand numerology, but this is a very strange number .... The fact is that a couple of years ago my grandmother first told me about numerology and that the numbers are not random. After that I started to take a closer look at this and today when I came across the MAP sensor number I remembered reading on https://www.sunsigns.org/angel-number-1111-meaning/ about the secret values ​​of this number. You may not believe in it, but it seems to me that this is true.
drod8719
Avalanche
Sep 7, 2017 5:44 PM
Mohamed Rezk
Sonic (Aveo)
Dec 19, 2016 2:51 AM
V70tdi
Jul 11, 2008 10:57 AM
