Spark Originally known as the Beat, , this Daewoo Matiz based 5 door hatchback is newest to the Chevrolet lineup
Chevrolet Spark
2014 Chevy spark no power to AC FUSE.
Old Jun 24, 2021 | 11:13 PM
Greasehead's Avatar
Default 2014 Chevy spark no power to AC FUSE.
Ac has no power going to the 10amp fuse if I jump power to the fuse the ac will turn on and run fine. Has the correct amount of freon and blows cold when it is bypassed. I noticed that the AC stopped working when my cooling fans started to run 24/7 while the vehicle is running.nothing is overheating I also changed coolant temp switch at thermostat housing no change!. Messed with it for a while yesterday and the fans stopped running then the AC engaged began to work as it should let it sit overnight and now back to no AC??? Anyone have any ideas.AC RELAY SEEMS TO BE PART OF THE CURCUIT BOARD
Old May 13, 2023 | 2:38 PM
rockin5b's Avatar
Hello. This is obviously an old post/thread. Did you ever come up with a solution? I am very curious and hopefully you see this. Thank you for your time.
Old May 15, 2023 | 12:57 AM
MIKES19COLORADO's Avatar
Change Both The Relay And The Fuse. And You Are Correct. The AC Is Part Of The Circuit . Your Compressor Runs At Times To Remove Humidity In The Winter Or Your Windows Would Always Be Steamed Up . The Fans Do Come On, Thats Normal And Its A Good Thing
Old May 18, 2023 | 2:51 PM
Artem Kostenko's Avatar
Default I also need help with ac
My AC doesn’t work
When I press the button to turn on the cooling in the car it rarely works
I tried to take of the center console and see behind it but I don’t understand anything
Need advice on what might be the problem
GeneveConversionVan
11
Oct 17, 2020 1:03 PM
radar1234
Jun 26, 2018 1:55 AM
77chevyc10
May 10, 2014 7:34 PM
klemeeri
Jan 11, 2012 5:37 PM
Deltavox
Feb 22, 2011 6:44 PM
