Spark Originally known as the Beat, , this Daewoo Matiz based 5 door hatchback is newest to the Chevrolet lineup
Chevrolet Spark
No Start
Old Feb 9, 2016 | 2:02 PM
Jack_Pierson's Avatar
Default No Start
Helloy name is Jack and I have a 2012 Spark 5 speed manual. Engine will not crank. Battery is good with strong voltage. Clutch switch is also good because I checked it by jumping connector. All dash lights come on and everything works.
Please help
Old Feb 9, 2016 | 11:17 PM
any theft lights?
when keyed to the start position...can you confirm the starter relay is clicking?
If yes, its not a theft issue as the start request is being made.
Old Feb 10, 2016 | 8:20 AM
Default No start
Thank you Tech 2
The theft light is on and I have a lock and key guy coming over to check the transponder and reprogram key if needed.
Old Feb 10, 2016 | 2:40 PM
unlikely that both keys would be bad. find out the dtc that is set and post it here.
