Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
Best gear ratio for 35s and best overall tire?
Old September 23rd, 2012, 10:23 PM
atvrider647's Avatar
Default Best gear ratio for 35s and best overall tire?
Hey guys, I have a 2001 1500HD and I am looking at putting a 6 inch suspension lift and a 3 inch body lift.
I am looking for a good daily driver, highway tire, that still performs on the weekends in the dirt and mud.
EDIT: Best gear ratio for:
35s
37s
38s
Old September 24th, 2012, 10:39 AM
SWHouston's Avatar
Is your truck a "C" or a "K" ?
The tread patterns for Highway and Mud use are quite different. Many who wish the best performance in each task, get a second set of Rims, and change when that duty is required.
As far as the Gear Ratio...
It depends on the Engine Size and Loads you expect to pull/carry. I will say this, that usually "Mudders" don't select a very low ratio gear set, specially when using larger tires.
Old September 24th, 2012, 2:43 PM
It's neither, C/K stopped at 98. And I am taking best gear ratio for highway driving.
Old November 21st, 2012, 7:57 PM
Southerncadillac's Avatar
if your going with 9 inches of lift total i would throw some 37's on there. tire best all around toyo open country mt's ive had mine for 10k miles and they have over 90% tread left. they pull real hard in the mud, gotta have 4x4 though cause they dig deep in 2wd. they arnt very noisy and they look great i will definentally be buying another pair. and as for gearing i would go with some 4.56's
Old December 5th, 2012, 1:29 AM
jameSjohns's Avatar
wheel that are best all around toyo start nation mt's ive had my own for 10k kilometers and they have over 90% take remaining. they take actual difficult in the mud, have to have 4x4 though cause they dig strong in 2wd. they arnt very loud and they look excellent i will definentally be purchasing another couple. and as for gearing i would go with some 4.56's
Old December 5th, 2012, 7:37 AM
chevroroman's Avatar
I think that the size of the tires should be the same as your dealer recommends you. You can variate with brands. But you can't with the sizes.
NorthWoodsDave
Silverado & Fullsize Pick-ups
10
May 8th, 2022 12:41 AM
dpainter68
December 7th, 2012 10:22 AM
tbb2
Express & G-Series Vans
July 31st, 2011 4:21 PM
josh2500
January 6th, 2008 10:18 PM
bracket boy
May 21st, 2007 10:09 AM
Quick Reply: Best gear ratio for 35s and best overall tire?
