Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
Lift on a chevy 2500hd
Old October 27th, 2009, 5:57 PM
judnick58's Avatar
Default Lift on a chevy 2500hd
Thinking about purchasing a 08 2500hd with a 7" lift. Are there any issues that Im going to run into with ball joints or other parts that seem to have problems with lift kits? Anyone have any ongoing issues once you get into the higher miles?
Thanks for any input!
Old October 27th, 2009, 5:58 PM
judnick58's Avatar
Oh also, how is the ride in this truck with a 7" lift?
Old October 27th, 2009, 6:48 PM
Ride of the Month
May 2009
mudmaniac's Avatar
We would need to know what brand of lift is installed to give you a good answer.
Some of the lifts don't change the ride too much other than stability, I would also assume that it has larger tires and may need a gear change to compensate for that.
Old October 27th, 2009, 8:20 PM
judnick58's Avatar
The truck has a superlift 7" lift with 35" tires and a PPE excelerator program tuner. Thanks for the help. Mainly I am most concerned with the issues I may have with replacing failing parts on my truck due to the lift. I have heard of many guys that have had to replace parts in lifted 1/2 ton trucks and say they will never buy a truck with a lift again. This will be my everyday vehicle.
Old October 28th, 2009, 7:58 PM
Ride of the Month
May 2009
mudmaniac's Avatar
Here is a link to the lift you are talking about. http://www.superlift.com/Catalog.asp?P=K309&V=77
I don't think you will have much trouble with it but with the 35's you should still consider a gear change to keep your low end strong.
Old November 23rd, 2009, 6:01 PM
myotherchevyisablazer's Avatar
if its a dmax no need for gears with a 7" lift george.....
M3ftw32
Silverado & Fullsize Pick-ups
December 14th, 2013 7:12 PM
snipe10
November 8th, 2012 10:21 AM
BigRed922
July 1st, 2012 4:36 PM
2500HD2000
May 17th, 2012 4:31 PM
Quick Reply: Lift on a chevy 2500hd
