01 Suburban 5.3L Rattle on acceleration
Old May 16, 2016 | 6:43 PM
Kljohnson85's Avatar
Default 01 Suburban 5.3L Rattle on acceleration
I can't for the life of me figure out whats causing this problem...
After the car is warmed up and mostly when sitting idle for awhile, the truck has a loud RATTLE when accelerating. It sounds like the timing being off in an older vehicle. I changed the plugs, wires, all fluids, exhaust system, u-joints. I don't know what ut could be... any ideas? Anyone else having or had same issue?
Old May 19, 2021 | 7:36 PM
Caseymayo212's Avatar
Got the same issue in my 03 suburban 1500. Been to three mechanics who still can’t figure out where it is coming from. No clue what it could possibly be. Any help would be greatly appreciated.
Old May 20, 2021 | 8:04 AM
repairman54's Avatar
I've had the belt tensioner get worn as the miles go on and rattle.
Also hit your cats with a rubber mallet and see if they rattle, inner cat honeycomb cores can get loose and rattle along with muffler baffles.
Old May 21, 2021 | 10:37 AM
Update: Crawled under the pass. Side yesterday and hit the cat with a rubber mallet. Reproduced the rattle perfectly all the way down the exhaust pipe. Wondering if there is anything I can do before completely replacing the converters. (Yes I live in a required emissions testing area).
Old May 22, 2021 | 6:47 AM
I would live with it if it's still running good until it doesn't pass inspection or starts running like exhaust is plugged up. Especially if it has California emissions as it's dealer only cats for those models as aftermarket cats aren't Cali. spec. only Federal spec..
Your probably going to have to due a complete exhaust system anyway as pieces of cat will be stuck in the muffler.
Old May 22, 2021 | 7:06 AM
Gonna have to do an aftermarket cat replacement. I bought the car two months ago and it already won’t pass an inspection. This is the only problem I’m having with it.
Old May 23, 2021 | 8:15 AM
Check your underhood emissions sticker to see if it has CA emissions. Many states require CA emissions not just vehicles sold in CA.
NJ, NY require CA emissions for example that I know of for sure. Many other states do also.
Fed cats will not work on a CA equipped vehicle, it will constantly set codes for cat failure.
GavinFraser
Nov 18, 2018 3:03 PM
03burb
May 31, 2011 9:50 PM
pcastillo58
Apr 30, 2011 12:37 AM
hids2000
Apr 15, 2008 12:33 AM
Sneak Attack
Jan 12, 2008 6:19 PM
