02 5.3 Tahoe stalling when put into gear
Old Oct 22, 2025 | 8:45 AM
bqd's Avatar
bqd
Default 02 5.3 Tahoe stalling when put into gear
So this has been a problem that appeared out of nowhere a month or two back, and I would start it up, wait a minute or two to warm up a bit, throw into gear and back out, but it would stall out, I had to bring rpms up to around 1500 and then put into gear and keep driving for about 10-15 seconds then I could come to a complete stop without it stalling, and it runs fine after that, only on startup after sitting for a few hours.
Old Oct 22, 2025 | 9:46 AM
Rednucleus's Avatar
When was last tune up; how many miles on vehicle? Any codes??
Old Oct 22, 2025 | 9:48 AM
bqd's Avatar
bqd
No clue on any tune up, but it’s at 320k and no codes, I just changed the knock sensor and went through this whole process of changing every sensor, since I just got it running again.
Old Oct 22, 2025 | 10:52 AM
Rednucleus's Avatar
I would start by changing plugs and wires with that many miles and no history of a change
Old Oct 22, 2025 | 11:20 AM
bqd's Avatar
bqd
Plugs, coil packs, wires all new, new IAC valve, tps, MAP sensor, crank and cam sensor all new.
Old Oct 24, 2025 | 9:20 PM
bqd's Avatar
bqd
So I have a p0420 code, and I know these are notorious for exhaust leaks, so I’ll try and fix that, especially because a couple bolts on the exhaust manifold are actually broke
emery25
Feb 20, 2025 5:11 PM
VonLanningham
Dec 10, 2024 8:56 AM
parrent01
2007 - 2013 (GMT900)
Nov 3, 2023 9:59 PM
piyush1
Cobalt
Nov 18, 2010 5:58 AM
killuminatii20
Dec 30, 2007 2:53 PM
