03 Suburban engine swap
Old Mar 14, 2020 | 10:27 PM
MrAxtell69's Avatar
Angry 03 Suburban engine swap
I have recently swapped the engine out in my 2003 Suburban. Everything is connected and hooked up properly. When I went to fire it up today, it didn't even turn over. The engine I put in is from an 04 Silverado. I noticed that the security light is now on as well. Any thoughts on what I can do to fix this myself and avoid having to pay for the tow truck and the dealer ship.
Old Mar 15, 2020 | 12:56 AM
did you swap the computer?
Old Mar 15, 2020 | 12:58 AM
MrAxtell69's Avatar
I did not swap the computer or anything else. Just the engine and that's it.
Old Mar 15, 2020 | 1:44 PM
did the engine run before you swapped it?
I dunno man there isn't a lot of info here to go on
Old Mar 15, 2020 | 3:44 PM
Rednucleus's Avatar
I assume it was running when you completed the swap? How long ago did yo complete the work and how long has it been running before the problem. Throw us a bone, lots more details would be helpful!
Old Mar 15, 2020 | 8:05 PM
MrAxtell69's Avatar
It was running fine before, I had bad head gaskets on mine and just decided not would swap engines. No issues before other than sludgy oil. I had about 280 on the old one and found one with only 129 on it so I jumped on it. Now I have a security light on and it says to service the air bag. Im not sure if I need to reprogram the ECM or if I could buy one online already programed and put it in. Sorry my post was not very informative, I wrote it on my smoke break at work. If you need more information please let me know. Not sure what else I can say other than I swapped out the engine and now my suburban is in security lock mode.
Old Mar 15, 2020 | 8:23 PM
Rednucleus's Avatar
Again, did it ever run after the swap?
Old Mar 15, 2020 | 8:26 PM
MrAxtell69's Avatar
No it has not run yet after the swap. I got it all hooked up and toped off with fluids. Got in and put the key in the ignition and turned it. Nothing, not a crank, not a noise, did not even seem like it was trying to turn over or start.
squeegy
Sep 12, 2019 12:42 AM
nic25276
Oct 4, 2016 11:25 AM
Dyang
Oct 2, 2016 11:23 AM
spade204
Feb 16, 2014 7:24 PM
princessauto
Feb 21, 2011 10:19 AM
