03 tahoe misfire only at idle!!! help
Old Jun 19, 2013 | 2:54 PM
ams69's Avatar
Default 03 tahoe misfire only at idle!!! help
my 03 with 5.3 has a dead miss at idle ONLY...will literally jerk the truck but never die , then you acclerate and it is as smooth driving and running as can be... has done this for almost 2 years and finally got bad and has threw a code (cant remember #) but basically has killed that catalytic converter .....i have read where a misfire will kill the converter so first i need to fix the misfire then replace converters any ideas???? would never have Check engine light until recent , had no idea where to start.
Old Jun 19, 2013 | 3:53 PM
Joe In NY's Avatar
Check Spark Plugs.
Clean throttle body. (controls idle)
Check for intake gasket leak.
Our 02 had a really bad idle right before we got the 07. Turns out it was the intake gasket had started a bad leak and running really lean. But fine off idle.
Old Jun 19, 2013 | 7:04 PM
Check the spark plug wires.
buddyleno
Mar 31, 2017 8:13 AM
Lussorocuztoms
Aug 14, 2012 10:13 PM
dtachia
Apr 23, 2011 12:55 AM
Biggumzmcgee
Nov 15, 2009 10:51 AM
