03 Tahoe towing issue
Old Mar 8, 2012 | 9:22 AM
Chevy Pit's Avatar
Default 03 Tahoe towing issue
I have a 2003 Tahoe that has the tow package on it. I went to pull my boat the other day and when I pushed the button on the shifter to turn on the tow helper button (don't know what its called). The light didn't turn on and it did not change the way the transmission is supposed to shift. I pushed it a few times and nothing. It did work last year but I only used it a few times during the spring.
Where to I start to look for the problem or does anybody have a idea what the problem is?
Old Mar 8, 2012 | 12:17 PM
hicksvilleshick's Avatar
seems that most times they are dirty, hitting them with air to dust them out sometimes helps. I've also seen reports of wires in the column breaking... the threads are out there but you gotta weed thru them.
I tore all into mine, ended up not doing anything to the wires but it started working again. I found if I pulled it down into 2nd or 1st and hit the button that would sometime get it to trip, and I just did it that way awhile till it started working from D...
:chug:
Old Mar 8, 2012 | 3:43 PM
Chevy Pit's Avatar
Thanks i will dig around and see what I come up with on the older post. I will try that trick tonight and see if that will make it work.
Old Mar 13, 2012 | 7:32 PM
valdeb2's Avatar
the switch button wire is broke, a common problem, the whole shift lever needs to be replaced
Old Mar 13, 2012 | 7:44 PM
valdeb2's Avatar
The tow mode button is in the shifter, when u move tilt wheel up & down the wire breaks, common problem on most GM trucks. To solve the problem the whole shifter to the steering column needs to be replaced. just did mine
D-Train
Mar 28, 2012 7:47 AM
Nyron
Jun 28, 2010 10:55 AM
Rodehard
Nov 18, 2008 8:44 PM
vrm
Mar 18, 2008 11:13 PM
ahjah9
Dec 7, 2006 10:20 PM
