04 Hoe..fuse keep's Blowing
I have 2004 Tahoe V8 5.3 Z71 car shut off on me so i decided to change the fuel pump fuse & it blew so i went to a 25 amp car starts but shut's after 3 Seconds Any clue
If you are having to put a larger fuse it that tells me there is a short somewhere. Put the correct apmerage fuse back in and start checking for pinched wire harness from when you did your fuel pump install.
Tkarcher
Nov 2, 2024 10:09 PM
