04 Suburban DIC Message- RFA 1 Battery Low-
Old Oct 16, 2014 | 11:19 AM
Jrstowe's Avatar
Default 04 Suburban DIC Message- RFA 1 Battery Low-
The DIC on my 2004 Suburban just started showing the message "RFA 1 Battery Low". This message is not referenced in the owners manual or anywhere I can find. Is it referring to the actual battery? It is a 2 year old die hard so it seems unlikely that it is needing replacement.
Also, is there a full "dictionary" somewhere that lists all the possible DIC messages and the meanings of those messages?
Thanks for any help.
jeff
Old Oct 16, 2014 | 4:55 PM
intheburbs's Avatar
I'm pretty sure it's telling you the battery is low in your key fob.
Old Oct 16, 2014 | 8:05 PM
intheburbs is correct.
Remember that Google is your friend ==> What does FRA 1 Battery Low mean? - Engine-Codes.com Q&A
Although they do keep a lot of data on us.
Old Oct 17, 2014 | 9:38 AM
I did not know that was a feature
I've always replaced my key fob battery when ever I felt its response was not what seemed normal....
Same with the vehicle battery, it almost always gives you that one warning opportunity... that one crank that seemed a bit slow or labored, better not ignore it....
trryhmmnd
Feb 4, 2025 8:23 PM
James Eagle
Oct 27, 2014 1:16 PM
89scottsdale
Sep 23, 2014 12:47 PM
89scottsdale
Sep 18, 2014 10:45 AM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
