04 Suburban door lock actuator on rear barn cargo door not actually bad. Now what?
I have an 04 suburban 1500 with dual rear barn doors. The lock actuator for the rear barn doors just suddenly stopped working with the lock switch and remote key fob. I assumed it was the actuator since I have had to replace some in the front doors in the past. So I got a replacement actuator and tried it and it still does not work. I took a little square 9 volt battery and some jumper wires and tested both the old and new actuators and they both work fine. I also had sanded the brass contacts and plates on both rear doors and no help. I have checked fuses also. All the other doors lock fine with the remote and with the door button. The rear door will lock with the key just fine. If I hit lock on the remote and use the key and unlock and open the rear door without hitting unlock on the remote then it sets the alarm off and makes the horn start honking. What else could be the problem?
Do the rear passenger doors lock AND unlock? You didn't say if the other doors will unlock. There is an UNLOCK relay that may be your problem. Do you have a test meter or test light? Check for power between the TAN and GRAY wires at the brass contacts on the right barn door when activating the door locks.
Yes all the other doors lock and unlock just fine with the door switch or the key remote. Yes I have a test light. If it ever stops raining here I will test those tan and gray wires at the contacts on the right door. Thanks for that info.
Where did you find the barn door actuator??
johndeerecharger
April 25th, 2019 12:07 PM
whodatiz59
March 27th, 2011 9:39 AM
