'04 tahoe Blend Actuator
Old Jun 8, 2010 | 9:27 PM
packman64's Avatar
Default '04 tahoe Blend Actuator
My wifes tahoe is having ac problems. When running the air, it will switch from front vents to defrost, blow cold air on one side and hot on the other etc. It seems to be only the front that is having the problems. The rear air seems to work fine.
The tahoe has the manual dual climate control (not digital).
I was told it was probably the blend door actuator.
Couple of questions:
1.) Where can i purchase one of these? What is part number. The only ones i see are for the auto temp control vehicles.
2.) Where is the thing located? Do i need any special tools to fix? Does it need to be reprogrammed?
thanks for all the help
Old Jun 8, 2010 | 10:05 PM
Welcome to the forum.
1.) Your dealer parts dept can get you the P/N and can order it for you.
2.) Can't help you there but someone here probably can.
Old Jun 15, 2010 | 5:01 PM
packman64's Avatar
was told it is actually a mode actuator that i need.
Anybody help???
JoeCB
Uplander
26
Mar 11, 2014 3:28 PM
los7883
Apr 12, 2010 9:36 AM
Jack
Sep 20, 2009 2:33 PM
john.m.hall
Sep 18, 2009 6:55 PM
2006trailblazer
Feb 24, 2009 1:58 PM
