05 tahoe - flex fuel to gas only
Old Apr 16, 2021 | 6:45 AM
David Meeneghan's Avatar
Default 05 tahoe - flex fuel to gas only
So I'm wondering what, if anything, would need to be done if I were to replace a flex fuel motor with one that was built for gas only.
I've got a high milage 5.3 with the flex fuel option, and a mechanic friendl has a freshly built moto that he'd sell me for almost nothing. It came from a gas only truck, and was rebuilt to those specs.
I know I would lose the ability to use the e85 (I dont use it anyway, so that's not a concern to me), but i was curious if there was any reason why a gas only motor wouldn't work if i dropped it in?
Would this be a straight plug and play, or would my flex truck need reprogrammed, or other parts replaced to go this route?
I've seen a lot of discussions about converting a non- flex motor to one that is, but what about going the other direction?
Old Apr 16, 2021 | 9:21 AM
the flex fuel differences are all in the fuel system. injectors, fuel lines, pump as ethanol would corrode metal in a build not designed for it.
Old Apr 16, 2021 | 9:57 AM
repairman54's Avatar
As tech2 said it's all in the fuel system. Stainless lines and a alcohol sensor in the fuel line to measure how much ethanol is in the fuel so PCM knows how to fire the injectors.
MikeySmiles
2007 - 2013 (GMT900)
Jul 19, 2023 1:46 PM
Hardin Thicke
Volt
Oct 17, 2012 1:10 AM
fromdodge2chevy
27
Jun 29, 2008 10:06 PM
mossimo
Jan 29, 2008 7:45 PM
MikeNAmyS
May 2, 2006 2:23 PM
