07 nav dvd C3 aux in help
Old Mar 6, 2008 | 11:19 AM
Tweek's Avatar
Default 07 nav dvd C3 aux in help
I have ordered the c3 harness from JPcustoms and it has the video and sterio sound out, but what pins do the aux in for video and sound on the oem nav with dvd sterio. I have extra clips for the connector, i am not sure what ones i can use. Does any one know the exact pins i would have to add to use the aux in on my radio?
Thanks
Old Mar 6, 2008 | 11:40 AM
sonnys007's Avatar
Default RE: 07 nav dvd C3 aux in help
Try this thread. This should answers your questions.
https://chevroletforum.com/m_15129/tm.htm
Old Mar 6, 2008 | 5:19 PM
Tweek's Avatar
Thanks, but that is mostly about the voice commands for the head unit and onstart. I did the listing for the pins on the C3 connector, but i am not sure what ones work with the Aux in? Anyone know from the list below what ones i have to soder the RCA to for the aux INPUT?
Thanks
16-Pin Connector C3:
Pin Wire Color Circuit No. Function
1 YE 2059 Auxiliary Audio Left Signal
2 WH 2058 Auxiliary Audio Right Signal
3 L-BU 5826 Left DVD Audio Signal (+)
4 WH 5828 Right DVD Audio Signal (+)
5 OG/BK 5831 Remote Infra Red Signal (+)
6 PK/BK 5844 Video Bright Control
7 D-GN 6975 DVD Video Signal (+)
8 PU 2056 Auxiliary Video High Signal
9 Bare 5345 Drain Wire
10 L-GN/BK 5845 Video Module Signal
11 PU 6979 DVD Audio Common
12 Bare 6980 DVD Audio Shield
13 TN/WH 5830 Remote Infra Red Signal (-)
14 Bare 6976 DVD Video Drain Wire
15 WH/BK 5335 DVD Video Signal (-)
16 Bare 5346 Video Drain Wire
Old Mar 7, 2008 | 9:48 AM
rruelas's Avatar
Pin 1 is for (+) Aux left audio input
pin 2 is for (+) Aux Right audio input
Pin 8 is for (+) Aux Video input
Its been a while since I hooked up my Video/Audio input connection.
but for the for the (-) connections, try the following:
pin9 (-) for Left and right common AUX input
and pin 16 (-) for Video common Aux input.
i wont have time to check till this sunday and verify how I have it connected but once I do, I let take pics and let you guys know.
Old Mar 7, 2008 | 7:03 PM
Tweek's Avatar
Woot,
Thanks. I would love to have pictures.
Old Mar 9, 2008 | 9:14 PM
rruelas's Avatar
I checked it out for you right after work. This works great for me.
pin 9 is for (-) left & right audio input common ground.
Pin 16 is for (-) Aux video ground.
To activate, just push the AUX button on the touch screen and there you go.
heres a pic of the third connector.
[IMG]local://upfiles/6152/079EDDC85C68492AB286E920A9C9F6C4.jpg[/IMG]
Old Mar 10, 2008 | 6:54 AM
Tweek's Avatar
Thanks rruelas. That picture is awsome. This will make my job so much easier. Thanks again.
oswaldjb
Apr 16, 2013 9:17 PM
NickRummy
Uplander
Oct 18, 2010 10:07 AM
cjasonsmith
Feb 21, 2009 10:50 PM
Tweek
Mar 14, 2008 8:35 PM
rruelas
Mar 9, 2008 9:07 PM
