07 suburban heated seat help
Old Feb 8, 2015 | 2:08 AM
Rbahri5206's Avatar
Default 07 suburban heated seat help
I have a 07 suburban and the passenger front heated seat is not working. The power seat works fine but the heat wont, when you hit the switch the switch does not light up or anything. The driver side works fine. Any ideas?
Old Feb 8, 2015 | 2:58 AM
Always check the fuses first. If the fuses are good then the next step is to check the switch and wiring.
Old Feb 8, 2015 | 11:04 AM
Rbahri5206's Avatar
I checked the underhood and under dash driver side fuses, no problems there did I miss any? Also how would I check the switch?
Old Feb 8, 2015 | 12:07 PM
sledge.impy's Avatar
http://www.justanswer.com/chevy/2p9d...orks-fine.html
Old Feb 8, 2015 | 10:30 PM
Rbahri5206's Avatar
Just a small update, i was driving the car tonight and noticed the lights in the switch were not working, do you guys think its a bad switch Or something elese?
Old Feb 14, 2015 | 3:02 PM
Rbahri5206's Avatar
Fixed it. So as i stated above everything worked (power seats both sides, Driver heated seat) the only thing not working was the passenger heated seat, the switch would not even glow at night so today I replaced the door handle because it was peeling, not covered because my car "does not have that problem according to GM" but that's another story for another day, anyways while I had the panel off I checked turns out the wire was unplugged.
CarolinaJ
Oct 14, 2012 4:05 PM
Sparkym300
Mar 29, 2010 8:09 PM
2004TahoeZ71
Apr 1, 2009 1:49 PM
slt780
Aug 6, 2007 10:42 AM
Mark_MS
Feb 12, 2007 2:24 PM
