07 suburban radio
07 suburban radio
I have an 07 suburban ltz the radio (Bose with DVD) switches modes randomly i.e. (fm xm am). It usually ends up on xm. I am stumped as what would cause this any ideas appreciated. Thank you
When you switch between functions, are you using the radio controls or the steering wheel controls? If you are using the steering wheel controls, try the radio directly and see if there is any difference. If the steering wheel controls are the problem, it is possible that they are sticking and need some cleaning. If the radio controls are causing the problem, look for any sign of sticking. It sounds like the button is sticking and one application of pressure is causing random events. Unfortunately, if the radio buttons are damaged beyond repair, you would need to have the unit serviced or replace the head unit.
You could visit your local car radio installation dealer and discuss the problem with them if you find that it can not be resolved.
jrsavoie
July 4th, 2011 6:18 PM
adamant
February 15th, 2009 8:49 AM
