07 Suburban Service Stabilitrak
Old Jul 18, 2011 | 10:10 AM
impdaddy's Avatar
Default 07 Suburban Service Stabilitrak
hi all. I have an 07 suburban 5.7 4WD. I have a service stabilitrak and service traction control as well as check engine light. It starts really hard like it sputters then clears out and runs. Shifts real hard and clunky from 1st to 2nd. Thoughts? Thanks
Old Jul 20, 2011 | 5:30 PM
Official GM Rep
impdaddy,
I am sorry to hear that you are experiencing this issue. Have you been into the dealership at all for these issues? If so, what did your dealership say?
Thank you,
Elizabeth, Chevrolet Customer Service
Old Jul 21, 2011 | 9:46 AM
impdaddy's Avatar
Elizabeth. No I have not. I was hoping to get some ideas here before I went to the dealer and before they just started throwing parts at it.
Thanks,
Old Jul 21, 2011 | 3:59 PM
Official GM Rep
impdaddy,
I completely understand. If you do go, let me know!
Thank you,
Old Aug 30, 2011 | 1:17 PM
gilstone's Avatar
Default Same problem...
Impdaddy,
I'm having the same problem w/ my '07 Suburban- were you able to fix it and if so, how?
Thanks,
-chris
Old Aug 31, 2011 | 8:26 AM
SabrToothSqrl's Avatar
Default yea
let me know too!
Did you know you can find skilled, intelligent, hard working people on 'the internet' as well as answers using Google? Google or bing, or yahoo?
these amazing services are yours... pretty much free.
I hope you find your answer, stealerships are not much fun.
Old Aug 31, 2011 | 8:51 AM
impdaddy's Avatar
Actually no I haven't fixed it. Best info I found on the internet is that it is probably a wheel/tire sensor. It still runs ok and just the annoying ding of the dash info is the down side. Anyone else have any good info? Thanks,
Old Sep 13, 2011 | 2:53 PM
RJK's Avatar
RJK
I had same isues also same lights service stabilitrak and service traction and CE.
If you have an 07 dont you have a 5.3 motor?
Mine was a bad throttle Body.
2007 57,000 miles when it went bad
Old Sep 29, 2011 | 1:37 PM
MSoko's Avatar
I have the same problem so I took it in to Autozone and they did a free diagnostic check. We got the code P2138 which is for the APP (Accelerator Pedal Position) sensor. You can Google the code and read a lot about what people have tried to do to fix it - I'm still struggling with it.
First I read that the error could be caused by a dirty/wet sensor. So I took it out, cleaned it (even though it didn't look dirty/wet) then plugged it back in. After driving 10 miles and restarting the engine, the light went off.
About a week later I had the same problem. So I pulled it out and plugged it in again and this time I drove it to the dealer. They replaced the APP sensor and accelerator pedal (or at least they say they did) and I didn't get any more problems for for about 2 or 3 weeks.
Last night it happened again. So naturally I pulled out the sensor with the engine off, let it sit for about 15 minutes, then turned it back on. The engine runs almost the same as "normal" engine, but the engine light as stayed on.
Now I'm thinking of replacing the battery, cleaning all wiring, and opening up the throttle body to see if it was really replaced.
Old Sep 29, 2011 | 2:41 PM
Default hmmm
if not, maybe the 'see your dealer' is a bit premature....
