07 Suburban Sunroof issue
Old Dec 26, 2015 | 3:38 PM
jelliott521@gmail.com's Avatar
Default 07 Suburban Sunroof issue
I have an 07 Chevy suburban ltz. I recently came across an issue with my sunroof not closing. Which is a problem since its December in chicago. When I pushed the buttons you can hear the click but no movement. I tried resetting and no click after 30 seconds.
Now the bigger issue, I became frustrated and read that I could hot wire the sunroof closed so I ended up ripping the wires out of the connector and breaking the connector. End story, the hot wiring didn't work. So now I'm stuck with an open sunroof and broken connector. When I researched looking for this part. It's out of stock everywhere.
The link below is the connect I need and broke. It's the connector which connects into the switch. Will the full wiring harness for the sunroof work? I'll even pull
from a junk suburban. HELP
http://www.partsgeek.com/j34dyw5-chevrolet-suburban-2500-sunroof-wiring-harness-connector.html?utm_source=shoppingcom&utm_medium=p f&utm_content=mc&utm_campaign=PartsGeek+ShoppingCo m&fp=pp&utm_term=Chevrolet+Sunroof+Wiring+Harness+ Connector&ul_ref=http%253A%252F%252Frover.ebay.com %252Frover%252F13%252F0%252F19%252FDealFrame%252FD ealFrame.cmp%253Fbm%253D954%2526BEFID%253D96477%25 26acode%253D905%2526code%253D905%2526aon%253D%2526 crawler_id%253D455941%2526dealId%253DJke0SxVAEMib7 WRJHQYRkA%25253D%25253D%2526searchID%253D%2526url% 253Dhttp%25253A%25252F%25252Fwww.partsgeek.com%252 52Fj34dyw5-chevrolet-suburban-2500-sunroof-wiring-harness-connector.html%25253Futm_source%25253Dshoppingcom% 252526utm_medium%25253Dpf%252526utm_content%25253D mc%252526utm_campaign%25253DPartsGeek%25252BShoppi ngCom%252526fp%25253Dpp%252526utm_term%25253DChevr olet%25252BSunroof%25252BWiring%25252BHarness%2525 2BConnector%2526DealName%253D2007-2008%252520Chevrolet%252520Suburban%2525202500%252 520Sunroof%252520Wiring%252520Harness%252520Connec tor%252520-%252520Standard%252520Motor%252520Products%2526Mer chantID%253D455941%2526HasLink%253Dyes%2526categor y%253D0%2526AR%253D-1%2526NG%253D1%2526GR%253D1%2526ND%253D1%2526PN%25 3D1%2526RR%253D-1%2526ST%253D%2526MN%253DmsnFeed%2526FPT%253DSDCF% 2526NDS%253D1%2526NMS%253D1%2526NDP%253D1%2526MRS% 253D%2526PD%253D0%2526brnId%253D1531%2526lnkId%253 D8072692%2526Issdt%253D151225190301%2526IsFtr%253D 0%2526IsSmart%253D0%2526dlprc%253D72.63%2526SKU%25 3D18977-07203156%2526op%253DIbxNt2jq%25257C42978181490%252 57Cm%2526srcrot%253D0%2526rvr_id%253D957312019279
