07 Tahoe Driver wheel makes rattle/grinding when turning at low speeds
Old Jun 20, 2022 | 3:14 AM
rysmith504's Avatar
Default 07 Tahoe Driver wheel makes rattle/grinding when turning at low speeds
Hey recently my Tahoe started making a rattling/grinding noise around the driver wheel. It is most prominent when turning the wheel all the way to the left at low speeds. The issue can be felt in the mostly in the floorboard but also in the steering wheel too. It is pretty much negligible when driving straight or turning right.
Also before the grinding issue turned up there has also been a POP that would happen around the same wheel if I gave too much gas when accelerating from a stop.
ABS and service traction control lights have been on for a while before this grinding issue happened. Brake pads are pretty new though. Anybody have any ideas?
Old Jun 20, 2022 | 7:57 AM
repairman54's Avatar
More than likely the bearings in the hub are shot.
Jack the wheel off the ground and look for play in it. May need to use a bar under the tire to ''flex'' it up / down enough as it's a heavy assembly.
ABS sensor is internal to the hub and if bearings are bad enough the ABS light will trigger. ABS scan is needed.
Dan75208
Dec 18, 2021 12:42 AM
dougm
Jan 14, 2020 2:11 PM
nole76
Jan 26, 2012 8:39 PM
2003burbnh
Jan 29, 2008 12:09 AM
CaddieKid
Dec 14, 2006 9:28 PM
