07 Tahoe Liftgate Defrost Wire Fell Off
Old Mar 31, 2011 | 9:21 PM
  #11
Ditto and be sure to stretch the coiled wires so they are hanging slack when the glass is closed.
Old Apr 15, 2012 | 2:53 PM
  #12
8tsixt's Avatar
Originally Posted by synack
I just fixed this today on my '07 Suburban. The TSB is right on. The part was less than $3, then $4 for Silver solder. I used one of those high temp solder guns. Rat Shack has them for $30 which is a ripoff as they can be had of less than half that elsewhere.
I made two loops of solder around the connector base, melted that with the gun while using needlenose pliers to hold. Then put the connector in position and applied heat. Whole soldering process was <10sec. Everything as a whole was <5 mins.
Thanks for the TSB!
I know it has been a while but did you remove the glass or do the repair on the car? Thanks!
Old Apr 15, 2012 | 3:03 PM
  #13
Its probably more personal preference, but removing it invites more potential problems then doing it in place...i.e. alignment issues, dropping it
Spread out some towels or an old blanket to protect from solder drip / spatter..
Use a pair of pliers to hold the connector and consider having a helper....
Old Apr 15, 2012 | 4:15 PM
  #14
See Post #11.
Old Jan 19, 2014 | 9:43 AM
  #15
fishing nut's Avatar
The defroster tab fell off on my 2011 Suburban yesterday. It looks like there is part of the tab on the window and the cord. I am planning on trying the pyrmex epoxy today to reattach. Is it recommended to replace the tab?? Has any one had any luck with the epoxy?
Old Jan 19, 2014 | 3:00 PM
  #16
Is that epoxy conductive? Make sure that the cord is slack when the glass is shut.
Old Jan 19, 2014 | 9:01 PM
  #17
The epoxy is conductive. Permatex sells a rear window defroster repair kit. I tried it today. I will post if it works or not tomorrow. You are supposed to wait 24hrs to turn on the defroster
EvansBlue
May 31, 2016 4:16 AM
The_Stees
Mar 5, 2013 8:20 AM
bans25
Uplander
Jul 15, 2011 7:40 AM
-Fidanza_
Feb 4, 2011 2:24 PM
dare2bgr8
Jul 12, 2005 12:49 PM
