07 tahoe nav part #'s (15940102 for exmpl)
Old Mar 12, 2007 | 6:55 PM
johnson374's Avatar
Default 07 tahoe nav part #'s (15940102 for exmpl)
Anyone know if this will work in a '07 tahoe?
Mine didn't come with nav so I am adding it.
It seems that '07 silverado, tahoe, denali....., should all work???
Thanks in advance for any help.
Old Mar 12, 2007 | 6:57 PM
ZX1100F1's Avatar
Default RE: 07 tahoe nav part #'s (15940102 for exmpl)
It will work and is a great buy for $899
Old Mar 12, 2007 | 7:42 PM
kcw002's Avatar
ZX... How do I know which NAV units will work with my LS? This Ebay seller has model # 15940103 & claims to be a nav unit only NON RSE cars... I'd like to add NAV to my LS, but ONLY if I can use the LockPick... Thats another can of works... Will I have access to use the lockpic and rear camera option...? I will search, but I think someone was mentioning a way for the deaer to program the head unit to yes for rear cam and then taping into the wiring pins and using a RCA jack with an aftermarket camera...
I dont need Nav, but the Lockpick, Ipod interface, and cam would make me a player to add it...
I am on the fence on this one
Old Mar 12, 2007 | 9:00 PM
johnson374's Avatar
Great, thanks for the info.
You're ontop of ebay I see :-)
Old Mar 14, 2007 | 6:45 PM
johnson374's Avatar
Hi, I just put the new nav in and hoping for some last bit of advise orone other question......
The dealers around here have never flashed a nav unit and don't know if it will take much longer than just a standard radio(because of programming codes, options, etc....).
Is it much harder to get through the options and you maybe know any codes or tips for me I can relay?
Thanks alot for any help on this.
Old Mar 14, 2007 | 8:46 PM
ZX1100F1's Avatar
First the menu will ask you to select which option code (U3U/UVB for nav) then the part# of the nav radio,
Then if you have the rear back-up camera and if so what style of vehicle (half-ton utilities, short wheelbase with RPO UVC for Tahoe)
Then speaker config (For vehicles with UQA speakers but withOUT RPO Y91 for Tahoe)
Next it will ask for the EQ setting select (For vehicles with UQA speakers but withOUT RPO Y91) once again.
Next The Tuner Region, select: (DVD Region 1 (NTSC); North America/Domestic Tuner Spec)
Then it will confirm all selections and download the new calibrations into Tech-2 which will then be loaded into your vehicle.
It is very easy and straight forward, the most common mistake that we see continually is the selction of Y91 which the 07 Tahoe does not have.
djvinevibez
Nov 18, 2012 2:05 PM
zmydust
May 20, 2010 10:48 AM
pete_dallas
Jul 27, 2008 2:03 AM
pete_dallas
Jun 22, 2008 2:41 PM
