08 burb a/c temp
Old May 24, 2020 | 4:58 PM
stayathomedad's Avatar
Default 08 burb a/c temp
My 08 burb a/c won't turn on.When I press the ac button, it flashed 3 times then goes off, it never come on. I have the auto temp control unit. What does the outside/inside temp have to be to turn on? I saw something about the ambient temp senor going bad, how do you test that? Is there any other typical problems? I just bought it this winter so I couldn't test it to see if it worked.
any help/ideas are appreciated
thanks
Old May 25, 2020 | 1:14 AM
One possible cause could be low freon.
Old May 25, 2020 | 10:52 AM
yep...first thing to check is charge level
Old May 26, 2020 | 2:16 PM
Default Update
System had .7 oz of freon in it. Small leak in rear lines right under the bracket. At least it's not in the wheel well and can be fixed without replacing the whole lines front to back.
Can someone recommend a good splice kit?
I see 2 ambient temperature sensor behind the grill. One is for the temp on the rearview mirror, what's the second one for?
Thanks
trlblzrman
Dec 3, 2018 8:40 PM
mediaguy
Uplander
May 20, 2017 9:27 AM
Hussain Afreed
May 21, 2016 11:04 PM
Aberry
Jun 7, 2011 11:29 PM
cmizikar
Mar 7, 2009 10:05 AM
