08 Tahoe One radiator fan not coming on.
I have only one fan not coming on. Should they both come on on low with the a/c? I’m assuming the fan is bad but could it be a bad fuse or relay if it’s just the one?
well i let the car cool down completely. Went outside turned it on and neither fan was on. Turned on the a/c and both turned on. Temperature was holding steady. Later I was in a drive thru and the temperature gauge started rising above normal. I pulled over and the right fan was off even though the other fan was going. I had the a/c on at the time and the temperature was about 90 degrees outside.
