08 Tahoe One radiator fan not coming on.
Old Apr 27, 2021 | 12:40 PM
Jose V's Avatar
Default 08 Tahoe One radiator fan not coming on.
I have only one fan not coming on. Should they both come on on low with the a/c? I’m assuming the fan is bad but could it be a bad fuse or relay if it’s just the one?
Old Apr 28, 2021 | 9:26 AM
Cusser's Avatar
Yes, could be faulty fan, relay, sensor, etc.
On something like a 20 minute drive with AC on, does fan #2 come on ???
Old Apr 28, 2021 | 8:11 PM
Jose V's Avatar
well i let the car cool down completely. Went outside turned it on and neither fan was on. Turned on the a/c and both turned on. Temperature was holding steady. Later I was in a drive thru and the temperature gauge started rising above normal. I pulled over and the right fan was off even though the other fan was going. I had the a/c on at the time and the temperature was about 90 degrees outside.
Old Apr 29, 2021 | 7:57 AM
repairman54's Avatar
I'd check for power to the fan motor when hot. Motor or relay can drop out after heating up. This way you know where to look.
Haciyev Mehemmed
Feb 2, 2021 11:22 AM
prostreet406
Nova & Chevy II
Nov 29, 2017 11:16 AM
Osterman42
Sep 1, 2017 7:49 AM
bojac
Aug 26, 2011 2:03 PM
htopball
May 6, 2010 6:00 PM
