08 Yukon Denali 6.2 elect problems
Old Feb 16, 2019 | 11:29 AM
Chevynomad1983's Avatar
Default 08 Yukon Denali 6.2 elect problems
sorry guys I posted this in general tech before realizing it belongs here so here it is
hey guys new member here and need some help with the wife’s Yukon Denali so here’s the deal right now it has an intermittent no crank(run through a few on off cycles it eventually starts) when it does start gauges bounce, speedometer does not move at all, and the gear indicator does not show current gear selected, when driving vehicle does not shift, and the rear hatch and window do not open. Attempted to hook a scanner to it and it will not communicate (it gets power and turns on) checked Fuses (under hood and passanger compartment) all are good. Looking for a good starting point for diagnosis or some schematics if at all possible, Thanks in advance
Old Feb 17, 2019 | 6:48 AM
When I had a 2011 Cruze, it would do similar things. The gauges went crazy but it started and ran. Turned out to be a bad battery. Got a new battery and everything started to work again.
