09 Tahoe does nothing in drive but does have reverse.
Old Sep 8, 2020 | 9:36 PM
Mear93's Avatar
Default 09 Tahoe does nothing in drive but does have reverse.
I picked up at 09 Tahoe at auction which motor runs strong. Put it into drive and get nothing, no sound like it tries to shift. Just revs like it’s in neutral but it does have reverse. Transmission fluid is full, although it appeared it may have a slow leak. Still after sitting in my yard for a week the fluid is still full which leads me to wonder what could be the deal. It gave a P0700 code with no other codes at that point. Check engine light is on but no idea what to mess with first. Any ideas?
Old Sep 8, 2020 | 10:29 PM
Welcome to the forum.
If you don't have a scanner, then most auto parts stores will scan for free.
Just curious, did it fail at the auction or after you drove it home?
Old Sep 9, 2020 | 1:28 PM
Mear93's Avatar
The auction did not have the key so we had to have it keyed before we left. It started right up but once in drive it did nothing. It had been scanned and gave a code of P0700 but that’s the only code it gave out.
Old Sep 10, 2020 | 8:24 AM
3Js's Avatar
3Js
2whl or 4x4?
Do you have any low gears? D1-D2
Common problem with 4L60E trans:
"No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken."
Old Sep 10, 2020 | 7:35 PM
Mear93's Avatar
It’s 2w no 4x4. It doesn’t have any forward gears. It’s like it’s in neutral and you press the gas to where it just revs up. It still goes in reverse and that’s all. Gives us one code with a OBD reader.
Old Sep 12, 2020 | 11:57 AM
do you have a 6 speed or 4 speed?
p0700 is a transmission general fault code. the trans is fubared. have a replacement trans installed. if any signs of metal is seen in the fluid...replace the trans cooler/rad and cooler lines or it will f the replacement trans.
hope you got this cheap. auction purchases are a risk...these vehicles come from dealers who know what is wrong and determine its not worth the time $ to fix.
Broomekrew
Feb 17, 2013 1:32 PM
BigBlock'Burban
Oct 5, 2011 3:53 AM
gcr2532
Aug 30, 2009 9:23 AM
five20too
May 10, 2008 11:05 PM
Kev
Jul 9, 2006 12:23 AM
