1981 suburban starting trouble/
Old March 16th, 2012 | 12:06 AM
uncledave57's Avatar
Default 1981 suburban starting trouble/
Suburban won't start in Park but starts in Neutral, any suggestions for this
happening? thanks for your insight...
Old March 16th, 2012 | 1:06 AM
Welcome to the forum.
I think there's a neutral safety switch that might need to be adjusted. Don't know where it is tho. Somewhere connected to the shifter and linkage.
Old March 16th, 2012 | 7:17 PM
RacerX's Avatar
I dont think it is the adjustment in the trans case, but it could be. I think the linkage in the steering column may be *****. The ignition switch only passes power through to the starter in P and N but if the gear selector is off a bit OR the switch is pretty odd, it is easy for the contacts to be off. Give the steering column selector a few jiggles as you try to start it in Park.
Old March 18th, 2012 | 1:19 AM
Thanks for the info..jiggles seemed to work..must be old and detent switch a little rusty works now woo hoo
Blessed3
July 25th, 2013 12:14 PM
lalo93
January 15th, 2012 2:51 PM
dozer157
September 8th, 2009 8:32 PM
Berend_Smit
May 12th, 2008 6:05 PM
