1989 suburban thermostat issue
Old Oct 19, 2014 | 6:56 PM
jsquires01's Avatar
Default 1989 suburban thermostat issue
I have been through three thermostats. Put new thermostat in, burb heats up, gets up to red line, thermostat finally opens, engine cools to normal. Finally after about three weeks of doing this the thermostat fails open and needs to be changed. Why is this happening?
Old Oct 20, 2014 | 10:28 AM
SWHouston's Avatar
Air in cooling system...
TStat butterfly valve hanging up on gasket or housing...
Before I'd buy another Stat, I'd get a pot of water, a A/C thermometer, and check the temps it opened when you heated the water.
Operating temp should be 185 deg, is that what it's at when it does open ?
Are you using a genuine GM Stat ?
Old Oct 20, 2014 | 11:02 PM
Rednucleus's Avatar
frontwards backwards upside down??
Old Oct 21, 2014 | 5:36 PM
jsquires01's Avatar
Default Thermostat issue
Thanks guys! I think it was an air issue. Refilled and let run awhile with radiator cap off. Seemsvto be doing ok now.
Thanks again.
FLV8Jeeper
Jan 23, 2022 12:16 PM
89scottsdale2500
Apr 3, 2015 8:27 PM
89scottsdale2500
Oct 8, 2014 3:43 PM
sevenhillsbilly
Aug 24, 2010 8:19 PM
kc8zdf
Jul 1, 2006 2:10 AM
