1993 suburban blend door actuator
Old Nov 25, 2010 | 4:45 PM
drezzz's Avatar
Default 1993 suburban blend door actuator
1993 suburban
V8 5.7 litre
I get air flow from the vent and floor settings but nothing from the defrost setting. It whistles and seems like the blend door actuator is not working but i cannot find the actuator for the defrost. I took out the glove compartment and found the actuator that controls the hot and cold settings but nothing more. Any help would be appreciated.
Old Nov 25, 2010 | 11:27 PM
15 Year Member
Welcome to the forum.
There's got to be a door and actuator that directs the air to the floor of defrost. Just don't know where it is. Maybe someone here knows the answer.
Old Nov 26, 2010 | 6:24 AM
RacerX's Avatar
did you pull out the radio and look back there? this system is all electronic so there should be like 3 or 4 of these actuators back there. I saw a few when I replaced the stereo but I didnt check their function.
Also look under the dash to the right of the steering column and see if you see anything.
Old Nov 3, 2011 | 5:53 PM
RacerX's Avatar
I cured this problem and posted the answer in a similar thread. Crawl under the dash and lubricate the top door lever and that should fix it.
DaniGirl
Jul 23, 2015 6:14 PM
JoeCB
Uplander
26
Mar 11, 2014 3:28 PM
Jack
Sep 20, 2009 2:33 PM
2006trailblazer
Feb 24, 2009 1:58 PM
