1994 Suburban dies on decel intermittently
Old Oct 24, 2012 | 6:32 PM
bdburb's Avatar
Default 1994 Suburban dies on decel intermittently
Hey everyone. I have a 1994 K1500 Suburban. It has 245,xxx miles on the chassis and 12,000 on the engine. Once and a while it dies when I let off the throttle when I'm driving in town. The dash lights and accessories seem to stay on when it happens. All I do is turn the ignition off then back on and it always starts right up. As far as stuff I have replaced(not cause of this issue) new distributor, rotor, cap, wires, plugs, tps, iac, map sensor, fuel pressure regulator, egr valve, egr valve solenoid and evap purge solenoid. It seems to idle erratic sometimes to. I'll be sitting at a red light and the engine will act like it's going to die and the brake pedal goes soft and it will try to lurch ahead, but it hasn't died when this happens. Any help would be great!!! Thanks
Old Oct 24, 2012 | 6:56 PM
GMcerttech's Avatar
sounds like a vacuum issue but i could be wrong
Old Oct 24, 2012 | 7:10 PM
bdburb's Avatar
That's what it seems like to me to but I checked for leaks and I couldn't find any.
Old Oct 24, 2012 | 7:11 PM
bdburb's Avatar
When it's cold and warming up it smells very very rich. Almost smells like there is pure gas coming out of the exhaust. It seems to miss to until it gets to around 90 degrees coolant temp.
Old Oct 25, 2012 | 12:18 PM
GMcerttech's Avatar
check for spark at cold start up and do an injector leak down test. you also may have an intake or head gasket issue i would check for a leak there as well.
Old Oct 25, 2012 | 12:58 PM
bdburb's Avatar
The ignition system should be fine. From what I've seen in the past, whenever there is a miss due to a spark issue the tach will jump. It stays steady. I still have 2 years of warranty on the engine so I think I'll try intake gaskets first. I can't detect a leak but maybe when the temp is just right something opens up
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
MikeA
Aug 23, 2011 8:20 PM
jcastle
Sep 28, 2009 7:38 PM
jwboudreau
Apr 25, 2008 6:48 AM
cmmaloy
Sep 5, 2006 5:07 PM
