1994 Suburban Issues [Need Help]
Old Jan 8, 2013 | 9:20 PM
Phirewire's Avatar
Default 1994 Suburban Issues [Need Help]
Just traded my fiero for a suburban and have ran into problems already
The Main Issue is While driving the Service engine Soon lights goes on and off, at any speed or amount of throttle seems random. I don't feel any diffrence or hear any diffrence. When cruising at 65 on highway driving 3 miles it stayed off the whole time could be luck or part of it.
Issue 2: The hood won't open. Gonna ask him tomorrow about it, I pull the release thing and it doesn't do anything. Any suggestions on getting it open?
Old Jan 10, 2013 | 8:49 AM
hicksvilleshick's Avatar
get the obd codes pulled at any vatozone, pop hood release and then go bump the hood in the middle front, should pop right up.
:chug:
Old Jan 10, 2013 | 3:44 PM
Phirewire's Avatar
It is as followed:
This is what it did:
(Flash pause flash flash) Code 12
1 flash, pause 3 flash. (Flash pause flash flash flash)
3 flashes, pause 5 flashes. (Flash flash flash pause flash flash flash flash flash)
4 flashes, pause 3 flashes. (flash flash flash flash pause flash flash flash)
Anyone know what these codes stand for?
Also pulling the hood handle inside does nothing.
Old Jan 10, 2013 | 4:44 PM
kevinkpk's Avatar
GM OBD-1 Diagnostic Trouble Codes
For 1995-previous model year EFI-equipped GM vehicles. NOTE: Some codes not supported on all models, consult your specific vehicle's service manual for the correct trouble code list and description for your application.
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
You have a busted handle on the hood release. The twelve is normal as it isn't running.
Old Jun 8, 2013 | 9:15 PM
DCSCO's Avatar
Same hood latch problem on my '95. Pull release, bang top of the hood until it pops up. Shoot the latch with WD40 and then brush with some body grease. Works now.
2000c5
Aug 4, 2015 10:15 AM
mps2220
Jan 2, 2014 1:13 PM
Rev600mod
Jan 10, 2010 10:58 PM
johnnyfive
Jun 1, 2008 10:07 PM
#1DEER1I
Feb 12, 2008 10:44 AM
