1995 Burb brake control install help needed
Old Dec 7, 2008 | 8:54 PM
Chevypowerbaby's Avatar
Default 1995 Burb brake control install help needed
Hi,
I just bought a prodigy brake control and I'm looking for guidance as to which wires I need to splice into. I guess I am hard wiring it...stupid me, I thought I'd just be plugging it in.[>:]
Old Dec 8, 2008 | 12:10 PM
old dog's Avatar
Default RE: 1995 Burb brake control install help needed
well there's going to be no way around using a test light and probing the wires to find the cold side of the brake light switch i think the switch is above the brake pedal using a white wire .push the pedal when you probe it to find the hot and cold side i don't know if the wire connector's are to were you can just touch metal end with out probing the insulation .good luck .
Old Dec 8, 2008 | 2:53 PM
Thanks for your help. I didn't think there was any way around that either. I'll give it my best. Thanks.
ssimas
May 10, 2015 10:01 PM
Gforce65
May 2, 2015 1:21 PM
oldirty
Uplander
Sep 27, 2010 10:29 AM
tippy28
Jul 1, 2009 6:03 PM
tpar1220
Dec 31, 2007 10:58 PM
