1995 Suburban C1500 no start, good battery
Drove the old Burb over to Lowe's today to pick up some drawer pulls. Walked back out and got in the truck and she no startey.
Well, probably the battery's shot, I figure, which means the alternator's probably on its last legs as well. Luckily there was an NTB in the parking lot, so I went over there and got a new battery.
Put the new battery in, same condition. All lights on dash, no start. No solenoid noise, no relay click, nothing.
Well, I had to work, so I came back later ready for AAA to tow her home. Got in the truck to wait for the tow, turned the key just for fun, started up on the second try.
Any thoughts of where to look?
When it left you stranded at Lowe's, you say no start? Was it no crank? Got it to your house, started second crank. My guess is starter solenoid. i'd also suggest look at the battery cables also.
Cables look used but okay. Guess I'll have to get underneath and see what the starter end of the cables look like.
I was thinking something like a fuse but it's weird that it decided to work later on.
When it didn't want to crank it was complete silence. No click, no sound of solenoid engaging, nothing.
In case anyone wonders, it was the starter.
Tested the battery with a meter. All good there.
I got underneath and pulled the starter wire off, then put a meter on that and turned the key. Saw it was getting voltage.
Replaced the starter with a reman unit. Fires up with barely a touch of the key now.
Good times.
Good times.
