1995 suburban hesitates at low rpm
<hr style="color:#000000; background-color:#000000" size="1"> I have a 1995 Chevy suburban k1500 LS 4x4 5.7L with TBI. When I am driving down the road slowly and barely have my foot on the gas pedal, it seems to hesitate and surge a bit. Almost like it will die. It starts up just fine and runs good when I floor it. It only seems to happen at low rpms. I have replaced the cap, rotor, fuel filter, spark plugs, EGR valve, cleaned the IAC, cleaned the throttle body, tested the Tps sensor (which read 0.498 volts at idle). I think the catalytic convertor is broken inside could this effect my EGR valve operation? I also ran my codes even though I didnt have a check engine light on. I came up the a code 54 which means 1. fuel pump circuit fault or mixture control (M/C) solenoid fault or electronic control module (ECM) fault/EGR solenoid #2 failure (3.8L VIN1) 2. fuel pump relay. Any other ideas? I appreciate the help in advance!
<table class="tborder" id="post277533" align="center" border="0" cellpadding="6" cellspacing="1" height="91" width="461"><tbody><tr> <td class="thead">
</td> </tr> <tr> <td class="alt2" style="padding:0px"> <table border="0" cellpadding="0" cellspacing="6" width="100%"> <tbody><tr> <td class="alt2">
</td> <td nowrap="nowrap">
</td> <td width="100%">
</td> <td nowrap="nowrap" valign="top">
</td> </tr> </tbody></table> </td> </tr> <tr> <td class="alt1" id="td_post_277533">
</td></tr></tbody></table>
the68
July 21st, 2013 1:09 PM
alarum
July 17th, 2013 10:24 PM
dirt5150
June 20th, 2011 8:25 PM
