1995 suburban power loss
Old November 14th, 2011 | 3:47 PM
  #11
kevinkpk's Avatar
Originally Posted by Unknown1329
Damn autocorrect that is what I meant. Seafoam not seafood.
I know.
Old November 14th, 2011 | 4:48 PM
  #12
Unknown1329's Avatar
I forgot to add too that it will only do it in a gear. I sat in the car idling for 30 mins no problems as soon as I put it in gear to go it started the bogging down.
Old November 14th, 2011 | 5:18 PM
  #13
kevinkpk's Avatar
That sheds a new light. Not sure yet, what. Supper time.
Old November 14th, 2011 | 6:58 PM
  #14
DCSCO's Avatar
After dark, in dark look for some arcing along spark plug leads. If need be, use assistant, reverse, break and throttle to apply some load while looking.
Old November 14th, 2011 | 9:05 PM
  #15
kevinkpk's Avatar
Does your transmission use a vacuum modulator valve for shifting? If so, I'd look at that. I am, again, not that "up" on newer cars. My 96 Lumina uses a vacuum modulator valve why I ask.
Old November 14th, 2011 | 9:19 PM
  #16
Get your fuel pressure checked. And that full tank will weigh close to 300 lbs. Better drain it.
Old November 17th, 2011 | 8:37 AM
  #17
Dads Toy's Avatar
You might want to ohm your wires out to see if one of the new ones shorted out. I bought a cheap pair of plug wires once, ran great then started missing out, lost power. come to find out it was the new plug wire broke down. Have you done a compression test on the cylinders?
diver8718
January 13th, 2015 5:15 AM
codymack2
April 7th, 2014 2:28 PM
Tlindsey099
October 7th, 2013 10:36 PM
rteas48183
March 18th, 2008 4:59 PM
Quick Reply: 1995 suburban power loss
