1995 Tahoe
1995 Tahoe
My 95 Tahoe backfires through the throttle body. It run great cold until it hits 125°-170° it stalls & backfires. At 190° it stops backfiring & stalling and runs great. I changed the coolant temp senor next to the thermostat housing. It made no change. Any thoughts?
fuel
bad fuel? bad spark plugs? bad distributor?
so, you're saying the temp sensor is good then?
it's at the top of the engine, right? so when the coolant level gets low, it doesn't read properly?
what else changes on the engine temp sensor?
any codes? check engine light? I think that year had an OBDII right?
FRENCHEVY
February 27th, 2010 5:15 PM
